Trying to convert selected dashboards from my v2 to dashboards in my v3 and do not want to convert my navigation bar. I sent the converted files to a folder I see the JSON files but how do I get these to import into v3?
The V3 migration tool will output a package (to the path set with Outputfolder) containing your migrated dashboards (User/Packages/Migrated), you can copy this package to C:\inetpub\wwwroot\squaredupv3\User\Packages\ rather than copying the entire output.
Did you use the tool/script that comes With v3?
