How Can i copy a tile that I created in one dashboard to another dashboard. Have not used Json so please explain from UI perspective. otherwise show me Json code
Hi Sandeep,
It’s not hard, not when you know how to do it ?
First edit the dashboard you want to copy a tile from.
Then, edit the tile you want to copy, and select edit JSON.
Copy all the JSON code into clipboard.
Goto you new dashboard where you want to copy the tile to, create new tile, edit tile, edit JSON – Paste the json code, press ‘Apply changes’
And your done ?
Hi, Thanks for that it worked
That was easy and a real help as I have lots to copy
