HI,
I learned that via mustaches it’s possible to format strings. Can I also use it to add some HTML tags for colorization for example?
This page here below indicates it could be possibe: https://ractive.js.org/v0.x/0.8/mustaches
Thanks
Ruben
Fairly sure this is possible as you can call HTML in the mustache, and I’m also sure I’ve seen an example where the SQUP guys have pulled icons from other places. The video below shows the use of span:
https://youtu.be/PHziS6DzUUA?t=1135
Hi Jelly,
actually I have seen that video already, but seems that I missed that part!
Thank you very much
Thank you.
Not a problem
