Does anyone know how to make 2 SCOM servers actually work in tandem when one has an outage? I’m tired of coming in every Thursday and half my apps are unmonitored. A reboot of the patched server the night before solves the issue.
Thanks,
Gary
Thanks,
Gary
Hi Gary!
In short, you need three members in the resource pool for full redundancy.
“Resource pools apply a logic similar to clustering “majority node set”, where (< number of nodes as members of the pool > /2) + 1. At a minimum, there must be three members in the pool to maintain quorum, which must be more than 50% of the quorum voting members in a pool to maintain availability of the pool. If you only have two members of the pool, and one is unavailable, you have lost quorum.”
If you have only two management servers, there is added an third member who is an “observer” that can vote, but does not take any workloads. It’s only purpose is to vote if there is an even number of members in the resource pool (and you loose half av them. The observer is tipping the scale in the scenarios.
!! Make sure you have an “observer” enabled i your resource pool with 2 mgmt servers. !!
Single management server
https://docs.microsoft.com/en-us/system-center/scom/plan-resource-pool-design?view=sc-om-2019
