Jelly
1
I’m attempting to set up the ABC F5 BIGIP MP from the community catalog and I think I’m getting confused with the registry settings.
I’m certain the account details are correct and configured as per the guide, the only thing I wasn’t sure on is this.
The documentation states (screenshot, because PDF):
So what I have done is this:
Does this look correct?
Documentation: F5_BIGIP_OpsMgr/Monitor_F5_BIGIP_with_OpsMgr.pdf at master · Juanito99/F5_BIGIP_OpsMgr · GitHub
rubenz
(Ruben Zimmermann)
2
nearly correct. - You don’t need double slashes. For the documentation I exported the registry key to a file. There the slash became doubled.
Correct it should look like this:
I’ll update the documentation soon.
If you have further questions or comments, just let m know.
Ruben
rubenz
(Ruben Zimmermann)
3
Update: Management Pack and documentation updated. Please download and install the latest version.
Fixed bugs.
Thanks
rubenz
(Ruben Zimmermann)
4
Jelly, it is now possible to use custom port for the REST API access. – MP and documentation is updated.
Please let me know if it works.
Jelly
6
Quick turn around - thank you
Jelly
7
Is there any way I can specify a custom port for the API? We use https://server:8443/ for management.
