I’ve created a Powershell Script Based Monitor using Silect MP Author so that I will be able to schedule their runtime (e.g. Every Day – Sun – Thu).
Problem is,
That I also need the availability to adjust the interval time (e.g. Every 30 Seconds).
And for some reason, this is not a valid option to combine in the MP Author Wizard.
You can only choose from the 3 following options:
- None
- Daily
- Periodic
Does somebody know what is the Interval Time configured if the Daily option is been chosen?
Furthermore,
While examining the XML file MP Author has created,
I can see that when choosing the Daily options, the following elements have been created:
</Configuration>
<OverrideableParameters>
<OverrideableParameter ID="TimeoutSeconds" Selector="$Config/TimeoutSeconds$" ParameterType="int" />
<OverrideableParameter ID="DaysOfWeekMask" Selector="$Config/DaysOfWeekMask$" ParameterType="int" />
<OverrideableParameter ID="StartTime" Selector="$Config/StartTime$" ParameterType="string" />
<OverrideableParameter ID="EndTime" Selector="$Config/EndTime$" ParameterType="string" />
</OverrideableParameters>
<ModuleImplementation Isolation="Any">
<Composite>
<MemberModules>
<DataSource ID="Scheduler" TypeID="System!System.Scheduler">
<Scheduler>
<WeeklySchedule>
<Windows>
<Daily>
<Start>$Config/StartTime$</Start>
<End>$Config/EndTime$</End>
<DaysOfWeekMask>$Config/DaysOfWeekMask$</DaysOfWeekMask>
</Daily>
</Windows>
</WeeklySchedule>
<ExcludeDates />
</Scheduler>
</DataSource>
Can I just add New Element:
<OverrideableParameter ID="IntervalSeconds" Selector="$Config/IntervalSeconds$" ParameterType="int" />
And a New line in the Scheduler: tag for the IntervalSeconds Value?:
<IntervalSeconds>30</IntervalSeconds>
