So I am trying to build a state view that will show logical disks that are alerting on Low Disk space. While it's easy to create a State/Status view of Logical Disks in Critical states, I'm not having much luck in just showing those that are alerting or "Low Disk Space". When I create the
…this seems like it’s simple and I’m missing something…someone please set me straight.
You could achieve something similar to what you’re looking for with the Performance plugin, as below (you could then show the health states with Health State Highlighting). I’m not sure you can get what you're looking for with the Status plugin.
I should have mentioned, our management groups are large, so for our NOC view, we don’t use the Top N Bar views; those work best in our environment when we scale them down to specific system groups. Otherwise, this is what I would normally want to show.
