Hey there,
I am trying to do what you see in this picture:
My problem is that I can’t get those columns fitted equally. I edited the JSON but even if I put in an equal width it didn’t look equal.
How do you do it?
Thanks in advance
Hey there,
How do you do it?
Thanks in advance
This has been the most frustrating thing I have with Squared Up. My issue is when you tile these for example and want to do some sort of a grouping. Sometimes I don’t need a heading on every single on as the DA name is enough.
Fairly sure this is a UI bug, though if you drop out of edit mode, you’ll see it’s not present. Use an old-school technique to test it (piece of paper across the screen under the circles) to see if they line up?
