saars
(Liam Matthews)
July 10, 2017, 2:55am
#1
I have a TV that I want to show some Open Access dashboards on but I can’t seem to find any way of having them auto-rotate
I found the KB for this function in V2
Can anyone tell me how to do this, preferably through Squared Up, but if not maybe another method?
ervia
(Ervia)
July 10, 2017, 8:16am
#2
As far as I remember, that function isn’t available in Version 3 (I stand to be corrected).
There is an add-in for Chrome that performs the function. It’s called Revolver and auto rotates between open tabs.
JohnnyK
(JohnnyK)
July 10, 2017, 8:37am
#3
Are you looking for something that will just rotate through IE tabs? If the TV isn’t used for anything else, this PowerShell script will solve your problem:
Add-Type -AssemblyName “System.Windows.Forms”
do
start-sleep -Milliseconds 30000
[ System.Windows.Forms.SendKeys ]:: SendWait( “^{TAB}” )
While ( $i -ne 0 )
saars
(Liam Matthews)
July 11, 2017, 12:48am
#4
Thanks, I ended up trying a few of them. Took me ages to figure out what to search the extensions store for.
The best product for this ended up being URL Slideshow https://chrome.google.com/webstore/detail/url-slideshow/pdblffiahfjjldpkngdpaegghhamefam?hl=en-US
I would much rather have the functionality back in SquaredUp, but as long as it works I am happy
