Is there a way to automatic detect SQL express and separate them in the view from the full version SQL servers.
SQL Server express is discovered as any other SQL version:
Groups are created from this too:
There’s not a way to exclude these, though if you know which servers have them, you can use criteria to remove the servers in question from view in a dashboard. Below I have removed server1 from display:
Hi!
You could use this filter.
It does target only the SQL DB Engine and not the whole computer though. I could not find a class that contains all SQL versions so you need to create one filter for each version I´m afraid.
Oh, my! Didn’t know this - Thanks Jannep!
