With SquaredUp Cloud Notifications, it’s really convenient to send notifications to multiple destinations.
When ServiceNow is set as the destination for SquaredUp notifications, they appear as Self-Service Incidents, with the relevant information included in the Additional Comments section.
Here’s an example:
A customer requested an automatic way to populate the Configuration Item field in the Incident record. When SquaredUp sends the server name in the additional comments of the Incident. They wanted a solution to automatically map the CI field with the server name when a new incident is created.
I’ll outline how to parse fields in ServiceNow incidents using information from SquaredUp notifications.
Since the customer had already discovered Configuration Items in ServiceNow, the solution was to set up a Business Rule that would query the cmdb_ci table and populate the CI field with the correct server information based on the server name in the notification.
The CI field wasn’t initially present, so I added it using Form Designer before proceeding with the rest of the steps.
Note: To implement this solution, the user must have an admin role in ServiceNow.
Steps:
- Create a new Business Rule on the
Incidenttable in ServiceNow. The rule is set to trigger before the incident is saved, with the action set to insert which means the CI field gets updated right when the incident is created.
The filter conditions are set to match the filters used in your Incident table where Squaredup notifications are received.
In the Advanced section, I used the following script. It uses regex to extract the server name, then queries the
cmdb_citable to find the sys_id of the matching server. The fqdn column in the CMDB table contains the full server name in plain text, which made it easy to match and update the CI field on the incident with the corresponding sys_id.
(function executeRule(current, previous /*null when async*/) {
// Extract the server name from the Additional Comments section
var comments = current.comments;
// Match using regex
var serverNameMatch = comments.match(/([a-zA-Z0-9-]+\.int\.domain\.com)/);
if (serverNameMatch) {
var serverName = serverNameMatch[0];
// Query the cmdb_ci table for the matching server name
var ciGR = new GlideRecord('cmdb_ci');
ciGR.addQuery('fqdn', serverName);
ciGR.query();
if (ciGR.next()) {
// Update the CI field in the incident with the matching sys_id of CI
current.cmdb_ci = ciGR.sys_id;
} else {
gs.info("CI for server " + serverName + " not found.");
} else {
gs.info("No matching server name found in Additional comments.");
})(current, previous);
Once you receive a new incident, the CI will be automatically updated.
