I'm having some issues with the Azure Management Pack - I'm running SCOM 2012 R2
The MP brought in the Azure Subscription but as you can see it has no health sate. I can’t see any of the Azure VM’s either - has anyone has a similar issue? Any tips to get this resolved would be appreciated.
Anything in the event log for the servers in the Azure Monitoring resource pool? Is there any monitoring that targets the subscription? Open health explorer and expand out the categories to see if there are actually any monitors for it.
Hi Jelly, so it turns out that discovery was turned off hence why no objects were discovered… Strange as you’d have expected the discovery to be on by default hence why I didn’t even think of looking there. Thanks for your help anyway.
