Azure SQL Managed Instance (MI) Dashboard Pack
Hey All,
Has anyone in the community created a dashboard for Azure SQL MI?
We have the SCOM MP imported but wanted to see if anyone has created a dashboard for this MP before I start work creating one.
Thanks, Anthony.
Hi Anthony,
Did you ever get a chance to build dashboards around this? Would be good to know how you did it.
Cheers
I just created a basic one for our testing needs.
Scoped a few tiles to the SCOM objects (using the SQL MI MP discovered objects) for the discovered test MI’s (Managed Instances, Alerts, MI Databases, DB Active Connctions & DB Engine CPU Utilization) then due to some missing metrics in the SQL MI MP from Microsoft, I added a few SQL Tiles to query these based on requirements from our DBA Team, stuff like SQL MI Storage usage.
This is the dashboard that I did if you want to download it?
https://dashboards.squaredup.com/dashboard-pack/azure-sql-managed-instance-1370?version=4
Thanks to Sameer Mhaisekar in helping it get published.
Awesome, thanks!
