I have a bar chart (within a matrix tile) showing current connections into our Remote Access Servers (however the same could be applied to any IIS web server)
The bar chart only shows values up to a 100 as defined by the value template
“{{( Math.min(value, 100) )}}”
I have increased this value to capture up to 250 connections. However doing this does not re-scale the bar chart correctly (as show in my screen shots)
Can the bar chart be changed to scale it correctly based on the max value?
