can personal views be saved for staff?
Would like to save personal views so that all the members of my dept will be viewing the same columns. Is that possible or is there another way to configure the views so all are viewing all the same columns
Hi Karen,
Please can you confirm if this is for the matrix tile? or perhaps the alerts tile?
These are both configurable, though I’d like to understand more around your requirements.
Thanks!
Hi Karen,
All published dashboards do appear the same to all the users. Can you elaborate a little or perhaps a screenshot would help.
