I’ve run debugging on IE and the following is the Console output.
DOM7011: The code on this page disabled back and forward caching. For more information, see: http://go.microsoft.com/fwlink/?LinkID=291337
File: index
HTML1300: Navigation occurred.
File: index
HTML1202: https://scom/SquaredUp/logon/index?ReturnUrl=%2Fsquaredup%2Frotation%3Fid%3Dtest1&id=test1 is running in Compatibility View because ‘Display intranet sites in Compatibility View’ is checked.
File: index
File: index
SEC7131: Security of a sandboxed iframe is potentially compromised by allowing script and same origin access.
SCRIPT5009: ‘JSON’ is undefined
File: rotation, Line: 17, Column: 13
Navigation Event Separator
File: rotation
File: rotation
HTML1202: https://scom/squaredup/rotation?id=iog_dashboard is running in Compatibility View because ‘Display intranet sites in Compatibility View’ is checked.
File: rotation
Can anybody provide assistance, or a steer? We’ve just bought a big screen and the boss is anxious to show it off.
The symptoms are, that the three open access urls I am using each work individually without authentication, but when they are incorporated in the url that runs the json file, it prompts for authentication.
The requirement for a licence/authentication is a known bug in the revolving dashboards. It will not be fixed in V2, but may be in V3 when revolving dashboards are implemented.
The original issue has been resolved, thanks to Jelly.
One other issue, for posterity. If you are using open access dashboards, and they are complex, as one of ours is (with 15 embedded dashboards), then it can take a while to redraw each time it comes around on the revolving.
A potential solution to this is to use the Revolved Chrome add-in, which revolves open tabs. I haven’t used it yet, but it is used in the organisation.
‘Display intranet sites in Compatibility View’ is checked. - This suggests where the problem may be. In IE, click the settings cog > Compatability view settings > uncheck “display intranet sites in compatibility mode”
Yes, I followed the guide, and the individual embedded urls are open access, i.e. they don’t request authentication. It’s only when I launch it through the json that it prompts for authentication.
