The default home page in squaredup is the welcome page. Is there a way to change this?
regards,
Daya Ram
regards,
Daya Ram
Depending on which version you are using, you simply need to edit the navigation bar via Settings > Profiles. Whichever is at the front of the list is the first page that will be opened.
Caveat - If you are using the Everyone (Default) profile, this takes precedence over every other profile. In order to set a custom login page for another profile whilst items are in the Default, you would need to remove all items in the default first.
Thanks. It works.
