So I am trying to add this value to a custom label within a status dashboard
using {{Name}} | {{FirmwareVersion}} , but the display is coming up blank. Have also tried ticking the ‘load extended properties’ box, but still no joy.
What would be the best way to get the actual label of these values?
Click on sort
Then custom
And then look and see how the properties are written in there. That should show you the syntax that’s expected for the object. Then use that syntax in Label…if its different.
Wayyyyy back when this was around, I believe there was an issue pulling all properties for objects. It’s now resolved and in v3 you can pull any properties required. Hopefully, the friendly support folk sorted you out!
