I’m looking to build a Visio dashboard for my Citrix environment; are there any good ‘get started’ resources out there?
Have you checked out Squared Up’s KB for this?
http://support.squaredup.com/support/solutions/articles/207629-how-to-configure-the-visio-plugin
There are also a few youtube videos on this on their channel which you might also find helpful,
- https://www.youtube.com/watch?v=LEnSmcw5jY8
- https://www.youtube.com/watch?v=N_yhCaxl9Do
There’s also some useful resources available on the CitrixCloud blog;
Citrix Cloud – Downloads
SquaredUp webinar – Citrix Management Pack Overview
We need a bit more information to be honest. What are you trying to display? what components/measurements of the environment? Visio diagrams normally only display the status of a component, e.g. a visio entity could show the status of a server. If you want performance metrics or alerts, then a “normal” dashboard is your friend. And you can have multiple sections within the same dashboard, one of which is a visio diagram.
