Hi all,
Has anyone been able to successfully bypass the pre-login disclaimer screen which is provided by Citrix Storefront while using the Citrix Logon Simulator Management Pack/Test-CitrixApp.ps1 script.
Thanks in advance.
Hi all,
Thanks in advance.
Hi Slovece,
Â
if you open storefront in IE and get to the disclaimer screen, right click in the acceptance button and âInspect Elementâ and find the classname of the button
then add this to the login powershell test-citrixapp.ps1
$buttons = $internetexplorer.Document.body.getElementsByClassName(âbuttonclassnameâ)
foreach($button in $Buttons){$button.click()}
between
Open-InternetExplorer -SiteURL $SiteURL
and
Test-LoginForm
in the try box at the bottom
