Hi there,
is it possible to add the Class Name of the objects in the component title as sub labels?
Thanks,
Gunter
Hi there,
Thanks,
Gunter
It looks like you can see the class ID, but not the name.
Hit the {{ }} mustache editor to see all available properties that can be displayed.
More info:
https://support.squaredup.com/v4/Reference/Tiles/CustomLabelling/
Yes, thanks for the hint. Unfortunately class ID is not that useful, too bad.
Thanks for your respone.
Not a problem
SharePoint-2010.zip (2.02 KB)
I just saw in a webinar that you can use this label to show the class name:
{{classes[0].displayName}}
This will then show the highest classname of the object. Which gives you a bit more information to understand the object.
Good find! Thanks for letting the Community Know!
