Column widths in SQL Grid
Hello All,
see title - how can I set fixed widths (px) for certain columns?
Can’t find any functionality in the tile definition. I’m guessing maybe via editing the JSON?
Thx in advance!
M.
Hi Marcus
For advanced dashboard authoring and layouts, you should find this technical webinar helpful https://squaredup.com/blog/webinar-replay-dashboard-json-tips-and-tricks/
It’s not possible to adjust the column width in the SQL tile (or OMS/API) via json or otherwise. Might be worth dropping support a feature request :slight_smile:
Jelly - thx, will do!
