Community Management Pack Catalog Error
In my SCOM console when clicking on the Management Packs (Community) I obtain the following error message
Date: 10/25/2017 9:52:54 AM Application: Operations Manager Application Version: 7.2.11878.0 Severity: Error Message:
System.ArgumentException: Value does not fall within the expected range.
at Microsoft.EnterpriseManagement.ConsoleFramework.ConsoleJobs.RunJob(IComponent jobOwner, EventHandler1 jobMethod, Object[] arguments) at Microsoft.EnterpriseManagement.Mom.Internal.UI.Administration.AdminTreeView.RebuildTree() at Microsoft.EnterpriseManagement.Mom.Internal.UI.Administration.AdminTreeView.HandleTreeUpdated(Object sender, EventArgs e) at Microsoft.EnterpriseManagement.Mom.Internal.UI.Administration.AdministrationTreeViewController.OnTreeDataUpdated() at System.EventHandler.Invoke(Object sender, EventArgs e) at Microsoft.EnterpriseManagement.EnterpriseManagementGroupInternal.RefreshTypeCacheInternal(Boolean forceDatabaseSync, ManualResetEvent acquireCacheUpdateLockEvent) at Microsoft.EnterpriseManagement.EnterpriseManagementGroupInternal.Reconnect() at Microsoft.EnterpriseManagement.Mom.Internal.UI.Common.ManagementGroupSessionManager.Reconnect(IManagementGroupSession session) at Microsoft.EnterpriseManagement.Mom.Internal.UI.Console.ConsoleJobExceptionHandler.CheckConnection(IComponent jobOwner) at Microsoft.EnterpriseManagement.Mom.Internal.UI.Console.ConsoleJobExceptionHandler.ExecuteJob(IComponent component, EventHandler1 job, Object sender, ConsoleJobEventArgs args)
H Nathan
Thank you for the supper quick reply.
I have opened my console using the clearcacache parameter…
I am using SCOM 2016 UR3.
I tried directly from the SCOM MS and opening the console from my laptop.
On my laptop when clicking on the Discover Community Packs, I obtain a popup saying Failed to create the GitHubIndex Object.Unable to resolve the index location from http://www.mpcatalog.net/CatalogRepo and once I press ok on the that screen, I obtain a .net error
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.AggregateException: One or more errors occurred. —> System.Exception: Unable to resolve the index location from http://www.mpcatalog.net/CatalogRepo
at Community.ManagementPackCatalog.UI.Models.GitHubRepository.<PopulateClassFieldsFromResources>d__11.MoveNext()
— End of stack trace from previous location where exception was thrown —
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.GetResult()
at Community.ManagementPackCatalog.UI.Models.GitHubRepository.<PopulateDataFromRepository>d__9.MoveNext()
— End of inner exception stack trace —
at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
at System.Threading.Tasks.Task.Wait()
at Community.ManagementPackCatalog.UI.DiscoverCatalogPacks.PopulateCommunityManagementPackListFromGitHub(GitHubPackDetail[] packsToDisplay)
at Community.ManagementPackCatalog.UI.DiscoverCatalogPacks…ctor()
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at System.Activator.CreateInstance(Type type)
at Microsoft.EnterpriseManagement.ConsoleFramework.Wpf.GenericWpfViewConstructor.CreateView(Object parent, Type viewType, IViewParameters viewParameters)
at Microsoft.EnterpriseManagement.ConsoleFramework.ViewConstructor.BeginShow(ShowViewContext showViewContext, AsyncCallback callback, Object state)
at Microsoft.EnterpriseManagement.ConsoleFramework.Wpf.GenericWpfViewConstructor.CreateNonRecyclableView(ShowViewContext showViewContext)
at Microsoft.EnterpriseManagement.ConsoleFramework.Wpf.GenericWpfViewConstructor.CreateAndShowViewCore(ShowViewContext showViewContext)
at Microsoft.EnterpriseManagement.ConsoleFramework.Wpf.GenericWpfViewConstructor.ShowViewOperation.Begin(ShowViewContext showViewContext)
at Microsoft.EnterpriseManagement.ConsoleFramework.Wpf.GenericWpfViewConstructor.BeginShow(ShowViewContext showViewContext, AsyncCallback callback, Object state)
at Microsoft.EnterpriseManagement.ConsoleFramework.Wpf.ConsoleViewDisplayService.OpenViewJob(Object sender, ConsoleJobEventArgs args)
at Microsoft.EnterpriseManagement.Mom.Internal.UI.Console.ConsoleJobExceptionHandler.ExecuteJob(IComponent component, EventHandler1 job, Object sender, ConsoleJobEventArgs args) at Microsoft.EnterpriseManagement.ConsoleFramework.ConsoleJobsService.RunJob(ConsoleJobDescription jobDescription) at Microsoft.EnterpriseManagement.ConsoleFramework.WindowJobsService.RunJob(ConsoleJobDescription jobDescription) at Microsoft.EnterpriseManagement.ConsoleFramework.WindowJobsService.RunJob(IComponent jobOwner, EventHandler1 jobMethod, EventHandler1 errorHandler, Object&#091;&#093; arguments) at Microsoft.EnterpriseManagement.ConsoleFramework.WindowJobsService.RunJob(IComponent jobOwner, EventHandler1 jobMethod, Object[] arguments)
at Microsoft.EnterpriseManagement.ConsoleFramework.WindowJobsService.RunJob(EventHandler`1 jobMethod, Object[] arguments)
at Microsoft.EnterpriseManagement.ConsoleFramework.Wpf.ConsoleViewDisplayService.OpenView(String assemblyName, String typeName, String target, String item, String criteria, Object[] arguments)
at Microsoft.EnterpriseManagement.Monitoring.Console.Common.ConsoleDisplayWrapper.OpenView(String assemblyName, String typeName, String target, String item, String criteria, Object[] arguments)
at Microsoft.EnterpriseManagement.Mom.Internal.UI.Console.MomViewsDisplay.OpenMomView(IComponent component, ManagementPackView view, String target, String item)
at Microsoft.EnterpriseManagement.Mom.Internal.UI.Administration.AdminTreeView.LaunchView(AdminTreeDataNode viewNode)
at Microsoft.EnterpriseManagement.Mom.Internal.UI.Administration.AdminTreeView.HandleNodeSelected(Object sender, TreeViewEventArgs e)
at System.Windows.Forms.TreeView.OnAfterSelect(TreeViewEventArgs e)
at System.Windows.Forms.TreeView.TvnSelected(NMTREEVIEW* nmtv)
at System.Windows.Forms.TreeView.WmNotify(Message& m)
at System.Windows.Forms.TreeView.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2116.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Assembly Version: 7.0.5000.0
Win32 Version: 7.2.11878.0
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202016/Console/Microsoft.EnterpriseManagement.Monitoring.Console.exe
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
Thanks
Hello George Ch,
Thank you for your feedback and error report, I am looking into the issue and had one additional question when you have a moment.
When clicking on Management Packs (Community), is there a pop-up error with any additional information?
Could you please try clearing your console cache? Clearing this cache will refresh all of the local data the cache uses, including the Management Packs (Community) items.
To clear the cache: launch the console with the /clearcache flag.
Better instructions: https://technet.microsoft.com/en-us/library/hh212884(v=sc.12).aspx
