Hi
What URLs would we need to white list to allow access to the community management pack catalog via the Operations Manager console…?
Thanks
Hi
Thanks
Tricky. Looks like it’s GitHub:
https://github.com/MPCatalog/scom-community-catalog
But the MPs are hosted on a mix of GitHub and AWS.
The catalog will connect from the client machine though, so if you can run it locally, rather than the management server…
