Had the same problem. Closing the console and opening it did not solve it. So I updated .NET which kind of helped partially. The original error went away and the MP was able to create the alert override MP under Settings. However when trying to discover the community packs it throws another error (popup):
Failed to create GitHubIndex Object
Unexpected character encountered while parsing value: <. Path ” , line0, position 0.
Any idea?
Details:
Date: 11/29/2017 11:01:09 AM
Application: Operations Manager
Application Version: 7.1.10226.1239
Severity: Error
Message:
System.AggregateException: One or more errors occurred. —> Newtonsoft.Json.JsonReaderException: Unexpected character encountered while parsing value: <. Path ”, line 0, position 0.
at Newtonsoft.Json.JsonTextReader.ParseValue()
at Newtonsoft.Json.JsonReader.ReadForType(JsonContract contract, Boolean hasConverter)
at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)
at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)
at Community.ManagementPackCatalog.UI.Models.GitHubRepository.<GetManagementPackIndexUsingHttp>d__14.MoveNext()
— End of stack trace from previous location where exception was thrown —
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at System.Runtime.CompilerServices.TaskAwaiter1.GetResult() at Community.ManagementPackCatalog.UI.Models.GitHubRepository.<PopulateDataFromRepository>d__9.MoveNext() — End of inner exception stack trace — at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) at System.Threading.Tasks.Task.Wait() at Community.ManagementPackCatalog.UI.DataConnectors.InstalledCatalogQuery.CheckAndFillInstalledPacksList() at Community.ManagementPackCatalog.UI.DataConnectors.InstalledCatalogQuery.DoQuery(String criteria) at Microsoft.EnterpriseManagement.Mom.Internal.UI.Cache.Query1.DoQuery(String criteria, Nullable1 lastModified) at Microsoft.EnterpriseManagement.Mom.Internal.UI.Cache.Query1.FullUpdateQuery(CacheSession session, IndexTable& indexTable, Boolean forceUpdate, DateTime queryTime)
at Microsoft.EnterpriseManagement.Mom.Internal.UI.Cache.Query1.InternalSyncQuery(CacheSession session, IndexTable indexTable, UpdateReason reason, UpdateType updateType) at Microsoft.EnterpriseManagement.Mom.Internal.UI.Cache.Query1.InternalQuery(CacheSession session, UpdateReason reason)
at Microsoft.EnterpriseManagement.Mom.Internal.UI.Cache.Query1.TryDoQuery(UpdateReason reason, CacheSession session) at Microsoft.EnterpriseManagement.Mom.Internal.UI.Console.ConsoleJobExceptionHandler.ExecuteJob(IComponent component, EventHandler1 job, Object sender, ConsoleJobEventArgs args)
—> (Inner Exception #0) Newtonsoft.Json.JsonReaderException: Unexpected character encountered while parsing value: <. Path ”, line 0, position 0.
at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
at Community.ManagementPackCatalog.UI.Models.GitHubRepository.<PopulateDataFromRepository>d__9.MoveNext()<—
