Connect SquaredUp to Sentinel
Hi
I’m trying to built a dashboard for the Azure Sentinel API, but I’m struggling how to configure the integration connection using the Web API type. I assume it is Sign in to your account for the token URL, but I do not know what the auth url is in that scenario. In the Azure integrations these entries are hidden. Any one have some experience on this ?
Thanks
