it returns error because of the spaces included.
I tried to replace spaces with %20 or + in the statement but with no luck.
Those spaces are defined in OME’s REST access guide as a proper way, it works with Postman, but not in SquaredUp.
I don’t have Dell OpenManage but if I create a WebAPI tile with Telerik Fiddler configured as a proxy on the SquaredUp server it looks as though the GET request is sent by server in this format:
If this is the cause, then you may be better off using the PowerShell tile to call the API rather than the WebAPI tile, or maybe raise a Support ticket if you’re able to do so.
Hi masokisi,
Thank you for your time spent on this.
I have upgraded SquaredUp to latest version 5.5 earlier today, but that didn’t solve the issue. I will raise support ticket now to get more info.
Thanks again
