If you’re trying to connect with GCP (Google Cloud Platform) with the Web API data source, here are the settings that worked for me.
In this example, I was integrating with GCP Error Reporting.
1 Start by creating an OAuth 2.0 client ID in the GCP console:
- Application type: select
Web application - Authorised redirect URIs: add
https://app.squaredup.com/settings/pluginsoauth2
Once created, you will need to use the Client ID and Client secret below.
If you’re reusing existing credentials, see Adam’s note below.
2 Configure the Web API data source
- Base URL: from the GCP API docs e.g.
https://clouderrorreporting.googleapis.com/v1beta1/projects/<my-project-id>/ - Authentication:
OAuth 2 - Token URL:
https://oauth2.googleapis.com/token - Client ID:
<Client ID from step 1> - Client Secret:
<Client secret from above>
Authorization Scope: You can find this on the docs page for the HTTP endpoint e.g. for Method: projects.groupStats.list | Error Reporting | Google Cloud it ishttps://www.googleapis.com/auth/cloud-platform - How to send credentials to the Token URL:
Query string - Grant Type:
Authorization Code - Authorization URL:
https://accounts.google.com/o/oauth2/auth?access_type=offline&include_granted_scopes=true&response_type=code
It’s a good idea to save your data source settings before clicking Sign In, just in case something goes wrong and you lose the settings.
- Click ‘Sign in’
- If all goes well, you should be authenticated!
- Now you’re ready to make a test request. My test was:
- Endpoint path to test: groupStats
- HTTP method for the test:
GET - Send!
Hope this helps!
