Cookdown not showing all management packs when creating a tuning pack
I can only see as far down as OpsMgr.Self.Maintenance when i try and create a tuning pack from a management pack. There is no scroll bar but I can move down past the end of the displayed items (although i have no idea whaty is selected).
Is there a way around this? I’m using SCOM 2012 R2 on a 2012 R2 server. Have tried on 2 servers and get same result.
Thanks,
Ian.
Hello Ian,
That sounds like a UI bug or UI scaling thing that we need to look into. We’ve got a bug entered into our system and I’ll mark it as blocking for you and get to it as soon as we can.
For a workaround, could you try highlighting one MP and using the arrow keys to move the list down? It’s not ideal, but might be able to get things moving.
Thanks,
Nathan
Hi Nathan,
Thanks for your reply.
If I highlight the last visible entry it goes blue but when i then move down with the arrow key the blue bar moves down to the next entry and is partially visible but when I move down again it is totally out of sight.
If I expand the box so it is full screen height it still only shows down to the same point.
Cheers,
Ian
