Hi Team,
Need to create monitor for CPU,Memory,Diskspace … In which more than 80% should trigger Warning alert and if its greater than 90% should trigger Error alert. I’m not familiar with creating monitors with Visual studio. So could someone help me on this.
I would start with Kevin Holmans fragments.
I know what you are thinking. “Wait, what did he just say?” Well, hear me out. Over the years, there have been…
Est. reading time: 4 minutes
saiyadra
(SaiyadRa)
April 7, 2022, 3:50am
3
Hi Shekar,
Out of curiosity, why are you using Visual Studio to create the monitors? I think you can override the current Monitors in SCOM to set these up.
apstrother
(Tony Strother)
April 7, 2022, 12:27pm
4
Morning, did you get this figured out? It is super easy with SCOM to do the things you mention. What version are you using?
Tony
we are using SCOM 2016 version. can you help me on this
saiyadra
(SaiyadRa)
April 14, 2022, 1:01am
6
This is easier done through a remote session. I am based in New Zealand, where are you based?
saiyadra
(SaiyadRa)
April 14, 2022, 8:23pm
7
Hi Shekar,
I found this and thought this might be helpful in giving you some ideas on how to create alerts in SCOM.
Ever wondered how alerting works in SCOM? In this post, we will go through the basics of alerts in SCOM, how alerts are generated, and what options alerts have. 1. Introduction In this post, we'll go through some basics about alerts in SCOM. For...
Things to note would be:
the Correct names of the Alerts/Monitor you are trying to work on
everything you do/change in a setting is called an Override and these need to be saved in its own MP
anything new you create like monitors, groups , rule etc needs to go into its own MP.
Creating your new MP’s are usually referred to as Custom MPs and should be labled appropriately to easily be differentiated from the Default MPs
Hope these helps.
Below monitor type has been already used for this type of request. But we cannot create via console.
Microsoft.SystemCenter.HealthService.ConsecutiveSampleDoubleThreshold.
