I created a new perspective view where I can see all network adapters of a Hyper-V-Host.
The problem is that the common “Performance view” of the host shows me only the view “Bytes/sec” (Object = Hyper-V Virtual Network Adapter + Counter = Bytes/sec).
It´s working but… Is it possible to change the label manually to e.g. MBytes/sec?
You can change the label using Mustache formatting, or in your case just type Mbytes/sec and the dynamic value you want to add. e.g Mbytes/Sec - {{key.instance}} . However the value is based on the formatting by SquaredUp
