Our customer requires a dashboard view which will provide us the complete view of the URL availability which are under monitoring
You should have a Web Availability dashboard as part of the default dashboards.
Alternatively, you can use the json here:
"content": {
"_type": "layout/list",
"contents": [
"_type": "layout/column",
"columns": [
"width": 100,
"contents": [
"contents": [
"_type": "tile/alert-list",
"config": {
"display": {
"columns": [
"severity",
"name",
"monitoringObjectDisplayName",
"resolutionStateName",
"timeRaised"
"limit": 5
"source": {
"owner": [
"any"
"severities": [
"0",
"1",
"2"
"sources": [
"monitor",
"rule"
"states": [
"0"
"timeframe": {
"range": "Last24Hours"
"title": "Alerts",
"description": ""
"columns": [
"width": 100,
"contents": [
"contents": [
"_type": "tile/status",
"config": {
"display": {
"zoom": "column"
"source": {
"scope": {
"classId": "eb12c841-f66a-040f-2b1e-28233307f088"
"title": "Web Application Availability Collections",
"description": ""
"columns": [
"width": 100,
"contents": [
"contents": [
"_type": "tile/matrix",
"config": {
"context": {
"scope": {
"classId": "aacbcb3a-fc52-8918-3ef5-868d01b4a15f",
"extendedProperties": true
"title": "Web Application Availability Tests",
"description": ""
"id": "b4539636-cefc-487b-938c-733ebba63d13",
"title": "Web Application Availability",
"derivedFrom": "00000000-0000-0000-0000-000000000000",
"createdFromReference": {
"packId": "88374822-3dce-4a17-8479-4c2a5b475f51",
"itemId": "0983845a-0861-42c6-83bc-f4943c2c79f1",
"packversion": "1.1"
To add the above, create a new dashboard and open the json editor:
Paste the json in and hit apply.
