Dashboard example for "Management Pack to create SCOM monitors from any SQL query"
With great intrest I have watched the video
https://squaredup.com/blog/a-new-free-management-pack-to-create-scom-monitors-from-any-sql-query/
However, it was not clear how I can create a dashboard out of this.
Is there a video/demo or info available how to create a dashboard from the queried results?
You can use the Status tile to show the health of an object that you have created the monitor for. Or you can use the monitor tile to show the specific health state of the monitor that you have created the monitoring for.
Understanding the Scope is important, but you can just use the class of the object you have created.
Are you able to search for the object in the scope of a tile?
Because “the class” is not found by squaredup
