Is there a dashboard for SharePoint 2013 available??
Thanks
Thanks
There’s something weird going on with this post - I’ll do another one!
The Version 2 dashboard is available here.
You can convert this to a v3 dashboard with the migration tool available here.
When I try to upload this Zip file to import the dashboard, an error message occurs “There is no manifest in this file: the contained package is malformed or corrupt.” please help.
Could you please convert the file and upload it for v3? Somehow I am not able to convert it or the output is not what is required. Thanks for support in advance.
Yeah, I’m not sure why SquaredUp have not converted all the v2 dashboards to v3 already??
If you are importing this dashboard into version 3, you will first need to run it through the migration tool as per the post above.
