Hello, we have both the version (V4 & V5)running on the same server. Looks like everything is okay with V5. What would be the proper way to decommission V4 without messing up V5 ?
Hi
Removing from the add/remove programs should work.
When I went from v3 to v4, I installed IIS URL Rewrite module. After uninstalling SQ v3, I created redirects of the v3 folder to the v4. URLs are usually the same aside from the Open Access ones. Didn’t have that much so created specific rules for them as well.
I actually have everybody (notifications & stuff) point to /SquaredUp, then use URL Rewrite to send users to v5 folder.
