I was wondering how I would be able to create a dashboard that would show the logical disks for all windows operating systems that show the disks thresholds that are under the thresholds set for the disks?
This would be to assist capacity management with a dashboard they could easily view and see which servers are below the configure overrides.
I have critical for non system disks set to warning under 20GB but not alert and Critical under 10GB and generates and alert
I have done something similar. It only shows unhealthy disks (warning, critical). It scoped on different OS disk classes and different logical units.In version 2 you could tie a healt state monitor to performance views making the bars go red/yellow. You had to go into the XML files to edit the views. Don’t know if its still available in v3 though.
