My first experiment with Easy Tune.
I’ve created a tuning pack for the Management Packs: Windows Server 2016 Active Directory Certificate Services Discovery/Monitoring.
Which is display under Source: Local Store in the Tuning Packs folder from Easy Tune - Cookdown.
I selected the Tuning Pack Action “Tune Globally (all Object)” with selected level Discovery Only.
In the next step I create a custom management pack. After this I got the summary. Finish gave eventually an error:
Date: 29-7-2020 11:44:02
Application: Operations Manager
Application Version: 7.2.12150.0
Severity: Error
Message:
: Could not load management pack [ID=System.Library, KeyToken=31bf3856ad364e35, Version=7.5.8501.0]. The management pack was not found in the store.
An object of class ManagementPack with name System.Library was not found.
Microsoft.EnterpriseManagement.Common.ObjectNotFoundException: An object of class ManagementPack with name System.Library was not found.
at Microsoft.EnterpriseManagement.ManagementPackManagement.GetManagementPack(String name, String keytoken, Version version)
at Microsoft.EnterpriseManagement.Configuration.ManagementPackReference.GetManagementPack()
Does anyone know what I can do about this?
