I’m trying to import EasyTune for SQL version agnostics MP.
I did the hard work to optimize it for my needs and I decided to try it. When I click finish in wizard I’m reciving exception:
Note: The following information was gathered when the operation was attempted. The information may appear cryptic but provides context for the error. The application will continue to run.Microsoft.EnterpriseManagement.Common.ObjectNotFoundException: Nie znaleziono obiektu klasy ManagementPackRule o identyfikatorze 334b93d4-c30c-73e0-02e5-9c7fb1500226.
at Microsoft.EnterpriseManagement.Configuration.ManagementPackDatabaseReader.GetRule(ManagementPackElementReference1 reference) at Cookdown.EasyTuneCore.Models.WorkflowOverrideFactory.CreateRulePropertyOverride(OverrideValueEntry overrideValue) at Cookdown.EasyTuneCore.Models.OverrideCollection.CreateOverridesForGlobalTargeting(ManagementPack targetManagementPack, String configurationName) at Cookdown.EasyTune.UI.FrameworkSheets.SetNewOverrideWizard.OnSavePages(Object sender, PageFrameworkActionEventArgs e) at Microsoft.EnterpriseManagement.ConsoleFramework.WizardFramework.FireActionEvent() at Microsoft.EnterpriseManagement.ConsoleFramework.WizardFramework.OnCommitJob(Object sender, EventArgs e) at Microsoft.EnterpriseManagement.Mom.Internal.UI.Console.ConsoleJobExceptionHandler.ExecuteJob(IComponent component, EventHandler1 job, Object sender, ConsoleJobEventArgs args)
Get-SCOMRule -Id 334b93d4-c30c-73e0-02e5-9c7fb1500226
returns nothing (there is no such rule in my SCOM).
I was importing this tunning pack before new SQL MP was imported and it was finishing wizard without problems.
Now with all SQL MPs imported it is failing ![]()
What I’m doing wrong?
