Edit EAM Availability test frequency
Application Availability Monitoring in V4 runs either the builtin or custom powershell-script every 2 minutes, is there any way to edit the frequency this runs?
I am worried whether running the availability monitoring this often will put strain on Watcher-nodes and servers. Especially when running a custom powershell-script that tests several links on several servers.
i have just checked this with the simple URL monitoring but i am sure this will work with custom powershell,too.
In the console open the health explorer of the DA and drill down to the “Enterprise Application Availability Test (Web)” monitor. There you can easily override this monitors interval or the “Response Time Threshold”.
Best wishes
Fantastic! It is as you say, easily found in the Health Explorer of the DA. Thank you!
