Event Viewer TOP 10 dashboard
Goal: To see a servers top 10 Critical events from a certain eventlog (eq. HelpDeskEventlog)
If using SQL Grid (connectionstring?).
Keyvalue: Server: SrvFalcon01 Eventlog: HelpDeskEventlog User: Falken Pass: Joshua
Thx for helping
could powershell be the answer to this?
The PowerShell or SQL/ODBC tiles could be the answer. When you say EventLog, is it a Windows Event log? Or is it a text file, or is it something else?
Good point I was refering to the eventlog on the windows machine.
Ah, yes. Then PowerShell would be the tool of choice.
Something like this:
$start = Get-Date
$end = $start.AddHours(-12)
$result = Get-EventLog -LogName Application -Before $start -After $end
$result
If you want to see it per server then you should use an agent task to execute a script. Much like shawn suggestions.
$start = Get-Date
$result
If you have Kevin Holmans MP (link below) you can execute the task “Execute any Powershell” to run the script. Otherwise you could author your own PS-task if you have the knowledge.
