I have written a simple task to get events from the application log of the server but when i run it the columns are squashed into less than half of the screen width (as below)
Is there a way to get the results to use more page / screen width so everything in the event message isn’t squashed into a very narrow wrapped column?
I have seen an article using pscustomobject but I dont think that applies here as adding a column to the output just uses the same space and makes the columns narrower.
Hi, Yes it is a Powershell task but I already tried ft -autosize and -Wrap and they have no effect. It seems that there may be a limit on the total width in SquaredUp. I have used format-list as a workaround but really want it in columns. Thanks, Ian.
