Exporting questions
I have a couple of questions reguarding exporting. I see you can only export data as an image or PDF, will there be a way to export data, specifically table data to csv? Also is there anyway to export an image of a dashboard via API?
You can trigger a tile to request a data stream’s data via Cloud’s API (note: the API is only available in Enterprise tier). Using powershell, or your automation tooling of choice, you could happily export to CSV.
We’re soon to introduce scheduled sharing of dashboards too. I’ll leave it to a PM to talk about what that will look like, but I believe it’s close to release.
Great! Would love to hear about it!
