I’m trying to save my unsealed MPs to the store, but I get stuck on the “Squared Up Enterprise Application Monitoring Overrides” and it’s Unable to find and load referenced management pack: ‘SquaredUp.EAM.Library:1.2.6.64’. Where can I find the SquaredUp.EAM.Library:1.2.6.64 management pack? TIA
Welcome to the community!
If you’re missing the MPs you can find them in the SqauredUp application settings as described in the KB here: https://scomsupport.squaredup.com/hc/en-us/articles/4565701791389-Management-Packs-MPs-
Otherwise if you need to work with them directly for some reason you can (currently) download them from here: Enterprise Application Monitoring Library - Download SquaredUp
Or more generally their MPs are available here: Home - Download SquaredUp
Hope this helps!
EP
