roscom
(roscom)
March 20, 2018, 11:31am
1
I realise there is no way to group status tile by a custom field in the UI, but I was hoping I could achieve this in the script itself.
This particular one is for web availability monitoring. Default looks like this:
{{ “_type”: “tile/status”, “config”: { “context”: {}, “source”: { “scope”: { “groupId”: “b4db2dc3-eacb-3815-1c82-9d4736d4b0df”, “classId”: “8e5cb3e8-3a88-4301-a703-553772fe72dd”, “criteria”: “” }, “extendedProperties”: true, “alerts”: true }, “display”: { “label”: “custom”, “sublabel”: “healthstatesummary”, “group”: { “property”: “healthState”, “order”: “desc” }, “customLabel”: “{{properties.context}}” } }, “title”: “”, “description”: “”}
I was hoping I could set like this:
“group”: { “group”: { “property”: “{{properties.context}}”, “order”: “desc” },
But it doesn’t work.
Anyone know if I can achieve what I’m trying to do…?
Thanks
gavin
(Speedy)
October 1, 2018, 11:58am
2
Hi, did you ever find a way to do this?
Thanks
clarkd
(Dave Clarke)
October 1, 2018, 2:44pm
3
You’re able to do this by editing the JSON, however you won’t need to use the curly brackets ({{}}) as per your example – you just need to specify the name of the property, e.g. isAvailable or properties.categoryName .
For example:
"_type": "tile/status-block",
"config": {
"context": {},
"source": {
"scope": {
"groupId": "603c9394-cbf5-a5d1-be77-45c0d6755902"
"stepSummary": ""
"display": {
"label": "name",
"columns": 5,
"height": 5,
"fontsize": 5,
"sublabel": "healthstatesummary",
"group": {
"property": "properties.categoryName",
"order": "asc"
"description": "",
"title": ""
gavin
(Speedy)
October 1, 2018, 3:00pm
4
Thanks, that worked for the status block. Trying to get this to work with the status donut…
