On my dashboards (in both Squared Up and SCOM) my groups are grey, why?
The groups contain servers, which are all green. I was expecting the group to be green too.
When you create a group in SCOM it does not by default have a health rollup monitor, so the health state stays in the grey/uninitialized ‘no health information’ state. To show the health of the group members using the group object you will need to add a health rollup monitor.
Here is a blog that provides a very straightforward walkthrough with screenshots.
I found that even with the health rollup added, occasionally the health state does get out of sync. This article explains how to fix this. Here’s a summary of the steps:
An other easy way to do it, and a little bit faster if you have many to create is:
1 Click ‘Monitoring’
2 Click Discovered Inventory’
3 Search for the group
4 Click ‘Configure Health roll up’ under tasks on the right hand side
If you have this on lots of groups and want to quickly create health roll-ups I would suggest using the link below to use Tao Yang’s Management pack. It’s really easy to use.
http://blog.tyang.org/2015/07/28/opsmgr-group-health-rollup-configuration-task-management-pack/
Does the group contain any servers, what are their health states?
Thanks. Updated question.
Thanks! That’s awesome.
You need to have Tao’s management pack as suggested by MatthewWalsh for this. It might be worth updating your answer to include this.
Ooops so you do! Now if only we had an edit button…
Great stuff, I sometimes have this issue with Distributed applications, it can sometimes take hours for the health roll up. Hopeful
