Software AG Webmethods.? Monitoring/ SquaredUp OMS?
The product Software AG has what is called Computational memory metrics that need to be monitored. I am unsure of the REST API but that is a great pointer. It is run on a AIX platform.
I’ve not heard of this before and I’m unsure as to what you’re after. Are you trying to pull data from this product into Squared Up using a web API? SQUP supports a vast majority of Restful APIs, so provided this software has one, you can pull this data and place it on a dashboard in tabular or scalar form.
