Health State Rollup is showing critical when all servers are healthy
I have a small group of a few servers that are all healthy / green but the rollup is showing critical / red.
What can I do to fix this? Do I need to delete the monitor and re-create it?
Managed to answer my own question! In my search, I came across this article which explains how to fix an incorrect rollup monitor state. Here’s a summary of the steps:
  1. Download the System Center Internal Task Library
  2. Run the ‘Resubmit local cache for state change events’
  3. Your rollup is fixed!
This fixes the issue because it forces a recalculation of the roll-up monitor as well – awesome!
I have the exact same issue, thanks for the direct!
