How do I convert v2 dashboards to v3?
Thanks
Thanks
To convert V2 dashboards to the new V3 format you can use the migration tool that Squared Up released.
Details on the tool and how to use it can be found here: https://download.squaredup.com/downloads/download-info/migration-tool-v3/
Thanks Clark, however this is only useful if I have a v2 environment. What I would like to do is take a v2 downloaded dashboard and use it in our v3 environment. Is this possible?
I believe the script also has options to run against a directory. So you could download and unzip the dashboard and run it against that?
