In SquaredUp v2 I was able to easily reset the monitor in the same screen as when reassigning the state for an alert. I can’t find that option SquaredUp v3. Has that ability been taken away?
This feature is still available, it’s just a little deeper than it used to be.
Open the alert > Go to the Monitor Perspective > Click the monitor > Click Reset in the top right
I raised this with Support a little while ago and they’ve said they’ll be bringing the button back to where it used to be on the initial alert page. If you want to know when this will be available, drop support a message and they’ll attach your ticket to the development ticket. This way they can update you once they’ve fixed it ?
