I want to widen certain columns within an alert section and narrow others. Widen the Name column to show more info and narrow Severity and State as they are small anyway.
I don’t think that’s possible at the moment. It might be worth emailing [email protected] to raise it as a feature request.
Oooold Topic i now, but did you ever find the solution to do this in a alert tile/section
Regards
Unfortunately, this was never resolved… until now!
5.4 is right around the corner and there will be some display elements available in the Alerts tile, including the ability to adjust the column width. Keep an eye our for our next release, due out soon (4-6 weeks).
That sounds just so great… Looking forward to it
Thanks for the reply!
